Introducción
This is a guide on how to replace the fan component in the Lenovo IdeaPad 1 14IGL7. This is a guide if you are needing to replace the fan component on your device, if it is not cooling the device properly. Please take precaution when handling, to prevent damage to the device.
Qué necesitas
Remove the seven 5.5 mm screws that secure the fan using a Phillips #00 screwdriver.
Casi Terminas!
Conclusión
