Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement
Qué necesitas
  1. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, Side Panel: paso 1, imagen 1 de 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: paso 2, imagen 1 de 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement, USB 3.0 Expansion Card: paso 3, imagen 1 de 1
    • With your hands remove the 14mm screw that holds the cover on the back panel.
    • Gently pull the flap back to expose the expansion card retaining screw.
  4. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
  5. Lenovo IdeaCentre K410 USB 3.0 Expansion Card Replacement: paso 5, imagen 1 de 1
    • With moderate force, pull straight up on the expansion card to remove it from the computer.
Conclusión
3 personas más completaron esta guía.
Timothy Grebe
Miembro Desde 10/19/14
1,652 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 10-39, Amido Fall 2014 Miembro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Miembros de 4
18 Guías creadas
1Guía Comentario
Why is a USB 3.1 Gen 1 adapter card called TV Tuner? It is an adapter card. What you connect to it is irelevant.
TheLOD2010 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 1,421
