Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo IdeaCentre K410 Power Supply Unit Replacement
Qué necesitas
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: paso 1, imagen 1 de 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 2, imagen 1 de 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: paso 3, imagen 1 de 2 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: paso 3, imagen 2 de 2
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 4, imagen 1 de 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 4, imagen 2 de 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 4, imagen 3 de 3
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: paso 6, imagen 1 de 1
    • Remove the power supply unit by pulling away from the screw side and then out.
Conclusión
10 personas más completaron esta guía.
Timothy Grebe
Miembro Desde 10/19/14
1,652 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 10-39, Amido Fall 2014 Miembro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Miembros de 4
18 Guías creadas
1Guía Comentario
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 40
Todo El Tiempo: 4,830
