Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo IdeaCentre K410 Motherboard Replacement
Qué necesitas
    1. Lenovo IdeaCentre K410 Motherboard Replacement, Side Panel: paso 1, imagen 1 de 1
      • Lay the computer down on its side as shown.
      • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
      Pregunta a FixBot
      Agregar Comentario
    2. Lenovo IdeaCentre K410 Motherboard Replacement: paso 2, imagen 1 de 1
      • Gently slide the side panel straight back and remove from the computer.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, USB 3.0 Expansion Card: paso 3, imagen 1 de 1
      • With your hands remove the 14mm screw that holds the cover on the back panel.
      • Gently pull the flap back to expose the expansion card retaining screw.
      Pregunta a FixBot
      Agregar Comentario
    2. Lenovo IdeaCentre K410 Motherboard Replacement: paso 4, imagen 1 de 1
      • Use the Phillips #2 to remove the 8mm screw that holds the USB 3.0 Expansion Card in place.
      Pregunta a FixBot
      Agregar Comentario
    3. Lenovo IdeaCentre K410 Motherboard Replacement: paso 5, imagen 1 de 1
      • With moderate force, pull straight up on the expansion card to remove it from the computer.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, RAM Module: paso 6, imagen 1 de 1
      • Push down on the white clips on both sides of the memory module to release it.
      • Gently pull up on the memory module to remove it from the unit.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, CPU Fan: paso 7, imagen 1 de 1
      • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
      • Be careful not to strip the screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Lenovo IdeaCentre K410 Motherboard Replacement: paso 8, imagen 1 de 1
      • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, Heat Sink: paso 9, imagen 1 de 1
      • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
      • The screws do not come all the way out of the heat sink
      • Pull the heat sink straight up to remove it.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, CPU: paso 10, imagen 1 de 2 Lenovo IdeaCentre K410 Motherboard Replacement, CPU: paso 10, imagen 2 de 2
      • Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
      • Remove the 11 mm screw using a Torx #20 screwdriver.
      • Remove the cover and remove the CPU by gently pulling upward.
      Pregunta a FixBot
      Agregar Comentario
    1. Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Lenovo IdeaCentre K410 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
      • Unplug all cords attached to the motherboard.
      • The largest connection requires a significant amount of force to be removed.
      Pregunta a FixBot
      Agregar Comentario
    2. Lenovo IdeaCentre K410 Motherboard Replacement: paso 12, imagen 1 de 2 Lenovo IdeaCentre K410 Motherboard Replacement: paso 12, imagen 2 de 2
      • Remove all 6 8mm screws attaching the motherboard to the base of the tower using a Phillips #2 screwdriver.
      • Gently pull the motherboard from the unit.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
11 personas más completaron esta guía.
Timothy Grebe
Miembro Desde 10/19/14
1,652 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 10-39, Amido Fall 2014 Miembro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Miembros de 4
108 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 30
Ultimos 30 días: 57
Todo El Tiempo: 6,202
