Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo IdeaCentre K410 Heat Sink Replacement
Qué necesitas
  1. Lenovo IdeaCentre K410 Heat Sink Replacement, Side Panel: paso 1, imagen 1 de 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Heat Sink Replacement, CPU Fan: paso 3, imagen 1 de 1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 Heat Sink Replacement, Heat Sink: paso 5, imagen 1 de 1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
Conclusión
Timothy Grebe
Miembro Desde 10/19/14
1,652 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 10-39, Amido Fall 2014 Miembro de Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
Miembros de 4
18 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 30
Ultimos 30 días: 64
Todo El Tiempo: 1,054
