Saltar al contenido principal
Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement
Qué necesitas
  1. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Stand Base: paso 1, imagen 1 de 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 2, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 2, imagen 2 de 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 4, imagen 1 de 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 4, imagen 2 de 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 4, imagen 3 de 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 5, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 5, imagen 2 de 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: paso 6, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: paso 6, imagen 2 de 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 7, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 7, imagen 2 de 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: paso 8, imagen 1 de 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: paso 8, imagen 2 de 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: paso 8, imagen 3 de 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: paso 9, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: paso 9, imagen 2 de 2
    • Remove any tape that secures the WiFi antenna cables.
  10. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 10, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 10, imagen 2 de 2
    • Remove the single screw that secures that WiFi card to the motherboard.
  11. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 11, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 11, imagen 2 de 2
    • Lift the wifi card and then pull out the card.
  12. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: paso 12, imagen 1 de 1
    • Locate the two small cables connected to the wifi card and pull gently to disconnect them.
Conclusión
2 personas más completaron esta guía.
Jackson Blake
Miembro Desde 01/22/18
1,119 Reputación
9 Guías creadas
Equipo
Cal Poly, Team S16-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 22
Todo El Tiempo: 1,571
