Saltar al contenido principal
Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement
Qué necesitas
  1. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Stand Base: paso 1, imagen 1 de 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 2, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 2, imagen 2 de 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 4, imagen 1 de 3 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 4, imagen 2 de 3 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 4, imagen 3 de 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 5, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 5, imagen 2 de 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: paso 6, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement, Arm Stand: paso 6, imagen 2 de 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 7, imagen 1 de 2 Lenovo IdeaCentre AIO 510S-23ISU Arm Stand Replacement: paso 7, imagen 2 de 2
    • Lift up to remove the arm stand.
Conclusión
Una persona más ha completado esta guía.
Jackson Blake
Miembro Desde 01/22/18
1,119 Reputación
9 Guías creadas
Equipo
Cal Poly, Team S16-G3, Banghart Winter 2018 Miembro de Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 31
Todo El Tiempo: 2,522
