Saltar al contenido principal
Lenovo G780 Screen Replacement
Qué necesitas
  1. Lenovo G780 Screen Replacement, Battery: paso 1, imagen 1 de 2 Lenovo G780 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Screen Replacement: paso 2, imagen 1 de 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Screen Replacement, Screen: paso 3, imagen 1 de 2 Lenovo G780 Screen Replacement, Screen: paso 3, imagen 2 de 2
    • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
  4. Lenovo G780 Screen Replacement: paso 4, imagen 1 de 3 Lenovo G780 Screen Replacement: paso 4, imagen 2 de 3 Lenovo G780 Screen Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
  5. Lenovo G780 Screen Replacement: paso 5, imagen 1 de 3 Lenovo G780 Screen Replacement: paso 5, imagen 2 de 3 Lenovo G780 Screen Replacement: paso 5, imagen 3 de 3
    • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
    • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
    • Be careful not to break the thin plastic cover.
  6. Lenovo G780 Screen Replacement: paso 6, imagen 1 de 3 Lenovo G780 Screen Replacement: paso 6, imagen 2 de 3 Lenovo G780 Screen Replacement: paso 6, imagen 3 de 3
    • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
  7. Lenovo G780 Screen Replacement: paso 7, imagen 1 de 2 Lenovo G780 Screen Replacement: paso 7, imagen 2 de 2
    • With the back cover being removed from the screen frame, the back cover can be set aside.
  8. Lenovo G780 Screen Replacement: paso 8, imagen 1 de 3 Lenovo G780 Screen Replacement: paso 8, imagen 2 de 3 Lenovo G780 Screen Replacement: paso 8, imagen 3 de 3
    • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
    • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
  9. Lenovo G780 Screen Replacement: paso 9, imagen 1 de 3 Lenovo G780 Screen Replacement: paso 9, imagen 2 de 3 Lenovo G780 Screen Replacement: paso 9, imagen 3 de 3
    • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
    • With the screws removed the screen will be free to be lifted away from the screen frame.
Conclusión
Una persona más ha completado esta guía.
Riley Griffin
Miembro Desde 03/25/19
316 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G4, Henning Spring 2019 Miembro de IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,004
