Saltar al contenido principal
Lenovo G780 Heat Sink Replacement
Qué necesitas
  1. Lenovo G780 Heat Sink Replacement, Battery: paso 1, imagen 1 de 2 Lenovo G780 Heat Sink Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: paso 3, imagen 1 de 3 Lenovo G780 Heat Sink Replacement, Fan: paso 3, imagen 2 de 3 Lenovo G780 Heat Sink Replacement, Fan: paso 3, imagen 3 de 3
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: paso 5, imagen 1 de 2 Lenovo G780 Heat Sink Replacement: paso 5, imagen 2 de 2
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: paso 6, imagen 1 de 3 Lenovo G780 Heat Sink Replacement, Heat Sink: paso 6, imagen 2 de 3 Lenovo G780 Heat Sink Replacement, Heat Sink: paso 6, imagen 3 de 3
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: paso 7, imagen 1 de 2 Lenovo G780 Heat Sink Replacement: paso 7, imagen 2 de 2
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Conclusión
Riley Griffin
Miembro Desde 03/25/19
316 Reputación
3 Guías creadas
Equipo
IUPUI, Team S2-G4, Henning Spring 2019 Miembro de IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 603
