Saltar al contenido principal
Lenovo G70-80 Screen Replacement
Qué necesitas
  1. Lenovo G70-80 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Screen Replacement: paso 2, imagen 1 de 2 Lenovo G70-80 Screen Replacement: paso 2, imagen 2 de 2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Screen Replacement: paso 3, imagen 1 de 2 Lenovo G70-80 Screen Replacement: paso 3, imagen 2 de 2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Screen Replacement: paso 4, imagen 1 de 2 Lenovo G70-80 Screen Replacement: paso 4, imagen 2 de 2
    • Remove the battery.
  5. Lenovo G70-80 Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Open the laptop to face the screen.
  6. Lenovo G70-80 Screen Replacement: paso 6, imagen 1 de 3 Lenovo G70-80 Screen Replacement: paso 6, imagen 2 de 3 Lenovo G70-80 Screen Replacement: paso 6, imagen 3 de 3
    • Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
    • The bezel is the plastic frame around the laptop screen.
  7. Lenovo G70-80 Screen Replacement: paso 7, imagen 1 de 2 Lenovo G70-80 Screen Replacement: paso 7, imagen 2 de 2
    • After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
    • If you are having trouble removing the bezel from the LCD panel, pull both sides of the bezel towards you with your hands.
  8. Lenovo G70-80 Screen Replacement: paso 8, imagen 1 de 3 Lenovo G70-80 Screen Replacement: paso 8, imagen 2 de 3 Lenovo G70-80 Screen Replacement: paso 8, imagen 3 de 3
    • Use a screwdriver to remove the screws that secure the LCD panel to the computer.
    • Once the bezel is removed, you will see eight screws around the screen that secure the LCD panel to the computer.
  9. Lenovo G70-80 Screen Replacement: paso 9, imagen 1 de 1
    • Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
  10. Lenovo G70-80 Screen Replacement: paso 10, imagen 1 de 1
    • Disconnect the LCD panel from the computer by peeling the connector off.
  11. Lenovo G70-80 Screen Replacement: paso 11, imagen 1 de 2 Lenovo G70-80 Screen Replacement: paso 11, imagen 2 de 2
    • With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
    • There is one screw on each corner that connects to the mounting arms.
  12. Lenovo G70-80 Screen Replacement: paso 12, imagen 1 de 1
    • Remove the LCD panel.
Conclusión
2 personas más completaron esta guía.
Un comentario
how do you repair a whitescreen effect for a lenovo110 ideapad
sidney ifedha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,773
