Saltar al contenido principal
Lenovo G70-80 RAM Replacement
Qué necesitas
  1. Lenovo G70-80 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 RAM Replacement: paso 2, imagen 1 de 2 Lenovo G70-80 RAM Replacement: paso 2, imagen 2 de 2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 RAM Replacement: paso 3, imagen 1 de 2 Lenovo G70-80 RAM Replacement: paso 3, imagen 2 de 2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 RAM Replacement: paso 4, imagen 1 de 2 Lenovo G70-80 RAM Replacement: paso 4, imagen 2 de 2
    • Remove the battery.
  5. Lenovo G70-80 RAM Replacement, RAM: paso 5, imagen 1 de 3 Lenovo G70-80 RAM Replacement, RAM: paso 5, imagen 2 de 3 Lenovo G70-80 RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Remove the placeholder screws and pull off the backplate.
  6. Lenovo G70-80 RAM Replacement: paso 6, imagen 1 de 3 Lenovo G70-80 RAM Replacement: paso 6, imagen 2 de 3 Lenovo G70-80 RAM Replacement: paso 6, imagen 3 de 3
    • Carefully pull the two metal retaining clips away from the sides of the RAM module.
    • As the clips release, the RAM module should pop up at an angle.
    • Remove the RAM from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 36
Todo El Tiempo: 1,145
