Saltar al contenido principal
Lenovo G70-80 CD Drive Replacement
Qué necesitas
  1. Lenovo G70-80 CD Drive Replacement, CD Drive: paso 1, imagen 1 de 3 Lenovo G70-80 CD Drive Replacement, CD Drive: paso 1, imagen 2 de 3 Lenovo G70-80 CD Drive Replacement, CD Drive: paso 1, imagen 3 de 3
    • Locate a Phillips head screwdriver. Use the screwdriver to remove the 2 screws found on the backside of the Lenovo G70-80. Once both of these screws are removed you will be able to remove the back of the laptop.
  2. Lenovo G70-80 CD Drive Replacement: paso 2, imagen 1 de 1
    • Next, you will need to locate the CD drive. If you orient the laptop with the hinge facing you, the CD drive will be in the bottom right corner near the battery.
  3. Lenovo G70-80 CD Drive Replacement: paso 3, imagen 1 de 1
    • Remove the screw to the left of the CD Drive.
  4. Lenovo G70-80 CD Drive Replacement: paso 4, imagen 1 de 1
    • Once all of the hardware in the previous steps is removed, you will be able to pull the CD drive directly out of the laptop.
Conclusión
Reassembly should be equally as easy as the disassembly. Follow the directions step by step in reverse order to reassemble the Lenovo G70-80 with your new CD drive.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,068
