Saltar al contenido principal
Lenovo G70-80 Battery Replacement
  1. Lenovo G70-80 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Battery Replacement: paso 2, imagen 1 de 2 Lenovo G70-80 Battery Replacement: paso 2, imagen 2 de 2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Battery Replacement: paso 3, imagen 1 de 2 Lenovo G70-80 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Battery Replacement: paso 4, imagen 1 de 2 Lenovo G70-80 Battery Replacement: paso 4, imagen 2 de 2
    • Remove the battery.
Conclusión
4 personas más completaron esta guía.
Un comentario
Very precise instruction, managed to not &&^& it up. Have a nice day good person!! :)
BodoGamer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 1,714
