Saltar al contenido principal
Lenovo G70-70 Keyboard Replacement
Qué necesitas
  1. Lenovo G70-70 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Lenovo G70-70 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo G70-70 Keyboard Replacement: paso 2, imagen 2 de 2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Keyboard Replacement: paso 3, imagen 1 de 3 Lenovo G70-70 Keyboard Replacement: paso 3, imagen 2 de 3 Lenovo G70-70 Keyboard Replacement: paso 3, imagen 3 de 3
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Lenovo G70-70 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Lenovo G70-70 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Keyboard Replacement: paso 5, imagen 1 de 3 Lenovo G70-70 Keyboard Replacement: paso 5, imagen 2 de 3 Lenovo G70-70 Keyboard Replacement: paso 5, imagen 3 de 3
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.2 mm Phillips #0 screws.
    • The label M2X6 is written next to each screw that keeps the keyboard secure.
  6. Lenovo G70-70 Keyboard Replacement: paso 6, imagen 1 de 3 Lenovo G70-70 Keyboard Replacement: paso 6, imagen 2 de 3 Lenovo G70-70 Keyboard Replacement: paso 6, imagen 3 de 3
    • Turn the laptop over so the top side is facing you and open the laptop.
    • Carefully pry open any corner of the keyboard with the metal spudger.
    • Slide the metal spudger around the perimeter of the keyboard until you can lift it.
    • You will hear loud popping noises as the keyboard separates from the laptop.
  7. Lenovo G70-70 Keyboard Replacement: paso 7, imagen 1 de 2 Lenovo G70-70 Keyboard Replacement: paso 7, imagen 2 de 2
    • Carefully lift the keyboard.
    • Use your finger or the opening tool to pull the locking flap toward yourself.
  8. Lenovo G70-70 Keyboard Replacement: paso 8, imagen 1 de 2 Lenovo G70-70 Keyboard Replacement: paso 8, imagen 2 de 2
    • Pull the silver ribbon cable away from you to disconnect the keyboard.
    • Remove the keyboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Joseph Crews
Miembro Desde 09/15/22
815 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 138
