Saltar al contenido principal
Lenovo G580 Keyboard Replacement
Qué necesitas
  1. Lenovo G580 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Place the laptop so the bottom is facing up.
  2. Lenovo G580 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the two M2.5x4 screws connecting the removable plate to the frame of the computer using a Phillips #00 screwdriver.
  3. Lenovo G580 Keyboard Replacement: paso 3, imagen 1 de 1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo G580 Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the three screws holding the keyboard to the laptop.
  5. Lenovo G580 Keyboard Replacement: paso 5, imagen 1 de 1
    • Open the lid of the laptop and locate the keyboard.
  6. Lenovo G580 Keyboard Replacement: paso 6, imagen 1 de 2 Lenovo G580 Keyboard Replacement: paso 6, imagen 2 de 2
    • Insert the plastic opening tool into the corner of the laptop between the keyboard and the side of the laptop.
    • Do not force the plastic opening tool as this will damage the laptop.
    • Slide the plastic opening tool across the keyboard towards the other corner.
  7. Lenovo G580 Keyboard Replacement: paso 7, imagen 1 de 1
    • Grab the keyboard at the corners and pull the keyboard off the laptop.
    • Make sure to disconnect the cord connecting the keyboard to the laptop before removing the keyboard.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 47
Todo El Tiempo: 4,354
