Saltar al contenido principal
Lenovo G580 Battery Replacement
Qué necesitas
  1. Lenovo G580 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure your laptop is oriented backside facing upward as seen in the image.
    • Locate the battery lock switch.
  2. Lenovo G580 Battery Replacement: paso 2, imagen 1 de 2 Lenovo G580 Battery Replacement: paso 2, imagen 2 de 2
    • Unlock the battery by moving the switch to the right.
    • The switch is unlocked when the RED of the switch is present.
  3. Lenovo G580 Battery Replacement: paso 3, imagen 1 de 2 Lenovo G580 Battery Replacement: paso 3, imagen 2 de 2
    • Hold the release switch down.
    • At the same time, push the battery upwards to remove the battery.
    • Pulling on the battery while the battery is locked will damage the laptop. Ensure the lock is properly disengaged.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 1,935
