Saltar al contenido principal
Lenovo G500S Touch RAM Replacement
Qué necesitas
  1. Lenovo G500S Touch RAM Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G500S Touch RAM Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G500S Touch RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure that your device is powered off and unplugged from the power source.
    • Flip your device over so that the back is facing you.
    • Using your fingers, push the tabs in opposite directions to eject the battery.
    • Remove the battery from the device.
  2. Lenovo G500S Touch RAM Replacement, Back Panel: paso 2, imagen 1 de 2 Lenovo G500S Touch RAM Replacement, Back Panel: paso 2, imagen 2 de 2
    • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
    • Remove the back cover from the device.
  3. Lenovo G500S Touch RAM Replacement, RAM: paso 3, imagen 1 de 3 Lenovo G500S Touch RAM Replacement, RAM: paso 3, imagen 2 de 3 Lenovo G500S Touch RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Push the silver hinges outwards to eject the RAM sticks.
    • Slide the ram out diagonally toward you and remove it from the device.
  4. Lenovo G500S Touch RAM Replacement: paso 4, imagen 1 de 2 Lenovo G500S Touch RAM Replacement: paso 4, imagen 2 de 2
    • Repeat the same instructions from the previous step to remove any extra RAM sticks.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 757
