Saltar al contenido principal
Lenovo G500S Touch Keyboard Replacement
Qué necesitas
  1. Lenovo G500S Touch Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G500S Touch Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G500S Touch Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure that your device is powered off and unplugged from the power source.
    • Flip your device over so that the back is facing you.
    • Using your fingers, push the tabs in opposite directions to eject the battery.
    • Remove the battery from the device.
  2. Lenovo G500S Touch Keyboard Replacement, Back Panel: paso 2, imagen 1 de 2 Lenovo G500S Touch Keyboard Replacement, Back Panel: paso 2, imagen 2 de 2
    • Remove the three 4mm screws on the back cover using the Phillips #00 screwdriver.
    • Remove the back cover from the device.
  3. Lenovo G500S Touch Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • With the back open, remove the three 6mm screws using the Phillips #00 screwdriver.
    • Remove two more 6mm screws using the same screwdriver.
  4. Lenovo G500S Touch Keyboard Replacement: paso 4, imagen 1 de 3 Lenovo G500S Touch Keyboard Replacement: paso 4, imagen 2 de 3 Lenovo G500S Touch Keyboard Replacement: paso 4, imagen 3 de 3
    • Using a metal spudger, gently pry under the keyboard from one corner.
    • Be careful of the strip connecting your keyboard to the laptop. Place your hand underneath the keyboard and carefully remove it from the laptop.
    • With the keyboard out, flip the lock holding the strip in place.
    • Remove the keyboard from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 976
