Saltar al contenido principal
Lenovo G50-80 80E5 Removing top panel Replacement
Qué necesitas
  1. Lenovo G50-80 80E5 Removing top panel Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Removing top panel Replacement: paso 2, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 2, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 2, imagen 3 de 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Removing top panel Replacement: paso 3, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 3, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 3, imagen 3 de 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Removing top panel Replacement: paso 4, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 4, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 4, imagen 3 de 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: paso 5, imagen 1 de 2 Lenovo G50-80 80E5 Removing top panel Replacement, Bottom Access Panel: paso 5, imagen 2 de 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Removing top panel Replacement: paso 6, imagen 1 de 2 Lenovo G50-80 80E5 Removing top panel Replacement: paso 6, imagen 2 de 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: paso 7, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: paso 7, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement, Keyboard: paso 7, imagen 3 de 3
    • Locate the 3 screws on the bottom securing the keyboard in place.
    • One Screw will be located under a Lenovo security sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Removing top panel Replacement: paso 8, imagen 1 de 1
    • Starting on the side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Removing top panel Replacement: paso 9, imagen 1 de 2 Lenovo G50-80 80E5 Removing top panel Replacement: paso 9, imagen 2 de 2
    • Continue prying around the top of the keyboard
  10. Lenovo G50-80 80E5 Removing top panel Replacement: paso 10, imagen 1 de 1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Removing top panel Replacement: paso 11, imagen 1 de 1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Removing top panel Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Removing top panel Replacement: paso 13, imagen 1 de 2 Lenovo G50-80 80E5 Removing top panel Replacement: paso 13, imagen 2 de 2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Removing top panel Replacement, Removing top panel: paso 14, imagen 1 de 1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Removing top panel Replacement: paso 15, imagen 1 de 1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Removing top panel Replacement: paso 16, imagen 1 de 1
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Removing top panel Replacement: paso 17, imagen 1 de 1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Removing top panel Replacement: paso 18, imagen 1 de 1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Removing top panel Replacement: paso 19, imagen 1 de 1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Removing top panel Replacement: paso 20, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 20, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 20, imagen 3 de 3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Removing top panel Replacement: paso 21, imagen 1 de 1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Removing top panel Replacement: paso 22, imagen 1 de 2 Lenovo G50-80 80E5 Removing top panel Replacement: paso 22, imagen 2 de 2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Removing top panel Replacement: paso 23, imagen 1 de 1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Removing top panel Replacement: paso 24, imagen 1 de 1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Removing top panel Replacement: paso 25, imagen 1 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 25, imagen 2 de 3 Lenovo G50-80 80E5 Removing top panel Replacement: paso 25, imagen 3 de 3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Removing top panel Replacement: paso 26, imagen 1 de 1
    • Top covered removed
Conclusión
12 personas más completaron esta guía.
Victor
Miembro Desde 10/17/17
1,309 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 75
Todo El Tiempo: 7,856
