Saltar al contenido principal
Lenovo G50-80 80E5 Fan Replacement
Qué necesitas
  1. Lenovo G50-80 80E5 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Fan Replacement: paso 2, imagen 1 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 2, imagen 2 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 2, imagen 3 de 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Fan Replacement: paso 3, imagen 1 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 3, imagen 2 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 3, imagen 3 de 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Fan Replacement: paso 4, imagen 1 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 4, imagen 2 de 3 Lenovo G50-80 80E5 Fan Replacement: paso 4, imagen 3 de 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: paso 5, imagen 1 de 2 Lenovo G50-80 80E5 Fan Replacement, Bottom Access Panel: paso 5, imagen 2 de 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Fan Replacement: paso 6, imagen 1 de 2 Lenovo G50-80 80E5 Fan Replacement: paso 6, imagen 2 de 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Fan Replacement, Fan: paso 7, imagen 1 de 1
    • Rotate the laptop so that you are positioned over the fan.
  8. Lenovo G50-80 80E5 Fan Replacement: paso 8, imagen 1 de 1
    • Remove the three 6 mm screws securing the fan using a Phillips #00 screwdriver.
  9. Lenovo G50-80 80E5 Fan Replacement: paso 9, imagen 1 de 1
    • Unplug the cable from the tri-color end connected to the motherboard.
  10. Lenovo G50-80 80E5 Fan Replacement: paso 10, imagen 1 de 1
    • Remove the fan from the laptop.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 497
