Saltar al contenido principal
Lenovo G50-70 Screen Replacement
Qué necesitas
  1. Lenovo G50-70 Screen Replacement, Screen: paso 1, imagen 1 de 3 Lenovo G50-70 Screen Replacement, Screen: paso 1, imagen 2 de 3 Lenovo G50-70 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Push the switches outwards to release the battery.
    • It is important to remove the battery in order to avoid the laptop from turning on and avoiding any electrical issues.
  2. Lenovo G50-70 Screen Replacement: paso 2, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 2, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 2, imagen 3 de 3
    • Use a flat head screwdriver (or a plastic opening tool) to pop off the screen bezel/ plastic cover.
    • Once one side comes off you can use your hands to pull the rest of the plastic cover off; it shouldn't take much force to remove it from the device.
  3. Lenovo G50-70 Screen Replacement: paso 3, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 3, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 3, imagen 3 de 3
    • After removing the plastic cover, gently tilt and lift the screen, but do not remove it from the device.
  4. Lenovo G50-70 Screen Replacement: paso 4, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 4, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove four 3.5 mm screws at the top right and left side of the screen.
  5. Lenovo G50-70 Screen Replacement: paso 5, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 5, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 5, imagen 3 de 3
    • Using the same Phillips #00 screwdriver, remove the four 3.5 mm screws at the bottom of the screen.
  6. Lenovo G50-70 Screen Replacement: paso 6, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 6, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 6, imagen 3 de 3
    • Once the screen is loose and can be moved around, make sure to readjust the laptop gently.
    • Lay the screen flat on the keyboard in order to make it easier to find the connector.
  7. Lenovo G50-70 Screen Replacement: paso 7, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 7, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of tweezers, peel the sticker to off of the device.
  8. Lenovo G50-70 Screen Replacement: paso 8, imagen 1 de 3 Lenovo G50-70 Screen Replacement: paso 8, imagen 2 de 3 Lenovo G50-70 Screen Replacement: paso 8, imagen 3 de 3
    • Carefully disconnect the display cable from the rest of the screen.
  9. Lenovo G50-70 Screen Replacement: paso 9, imagen 1 de 1
    • Remove the screen from the device.
Conclusión
2 personas más completaron esta guía.
Brandon Navas
Miembro Desde 10/05/21
217 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 54
Todo El Tiempo: 1,547
