Saltar al contenido principal
Lenovo G40-30 Speaker Replacement
Qué necesitas
  1. Lenovo G40-30 Speaker Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G40-30 Speaker Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G40-30 Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Speaker Replacement: paso 2, imagen 1 de 3 Lenovo G40-30 Speaker Replacement: paso 2, imagen 2 de 3 Lenovo G40-30 Speaker Replacement: paso 2, imagen 3 de 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Speaker Replacement: paso 3, imagen 1 de 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Speaker Replacement, Keyboard: paso 4, imagen 1 de 2 Lenovo G40-30 Speaker Replacement, Keyboard: paso 4, imagen 2 de 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Speaker Replacement: paso 5, imagen 1 de 2 Lenovo G40-30 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Speaker Replacement: paso 6, imagen 1 de 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Speaker Replacement: paso 7, imagen 1 de 2 Lenovo G40-30 Speaker Replacement: paso 7, imagen 2 de 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Speaker Replacement: paso 8, imagen 1 de 3 Lenovo G40-30 Speaker Replacement: paso 8, imagen 2 de 3 Lenovo G40-30 Speaker Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Speaker Replacement: paso 9, imagen 1 de 1
    • Now your keyboard is free to be replaced!
  10. Lenovo G40-30 Speaker Replacement, Hard Drive: paso 10, imagen 1 de 2 Lenovo G40-30 Speaker Replacement, Hard Drive: paso 10, imagen 2 de 2
    • Unscrew four 4mm JIS #0 screws.
  11. Lenovo G40-30 Speaker Replacement: paso 11, imagen 1 de 3 Lenovo G40-30 Speaker Replacement: paso 11, imagen 2 de 3 Lenovo G40-30 Speaker Replacement: paso 11, imagen 3 de 3
    • After you have the screws out apply pressure with your thumb and slide the hard drive to the left.
    • When the hard drive is completely left gently pull up on the right corner.
  12. Lenovo G40-30 Speaker Replacement, Speaker: paso 12, imagen 1 de 2 Lenovo G40-30 Speaker Replacement, Speaker: paso 12, imagen 2 de 2
    • Remove the nine 7mm screws with a JIS #0 screwdriver.
  13. Lenovo G40-30 Speaker Replacement: paso 13, imagen 1 de 1
    • Using the plastic opening tool split open the laptop on the ends. Starting from one side to the other.
  14. Lenovo G40-30 Speaker Replacement: paso 14, imagen 1 de 3 Lenovo G40-30 Speaker Replacement: paso 14, imagen 2 de 3 Lenovo G40-30 Speaker Replacement: paso 14, imagen 3 de 3
    • These two are the speakers.
    • This is the connector.
    • Unscrew the two 4mm JIS #0 screws.
  15. Lenovo G40-30 Speaker Replacement: paso 15, imagen 1 de 3 Lenovo G40-30 Speaker Replacement: paso 15, imagen 2 de 3 Lenovo G40-30 Speaker Replacement: paso 15, imagen 3 de 3
    • In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
    • Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
    • Next, use the tweezers to pull the connector out away from the screen.
  16. Lenovo G40-30 Speaker Replacement: paso 16, imagen 1 de 1
    • Now you are ready to install your new speakers.
Conclusión
Una persona más ha completado esta guía.
Randall
Miembro Desde 02/08/18
139 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,632
