Saltar al contenido principal
Lenovo G40-30 LCD Screen Replacement
Qué necesitas
  1. Lenovo G40-30 LCD Screen Replacement, Battery: paso 1, imagen 1 de 3 Lenovo G40-30 LCD Screen Replacement, Battery: paso 1, imagen 2 de 3 Lenovo G40-30 LCD Screen Replacement, Battery: paso 1, imagen 3 de 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: paso 2, imagen 1 de 3 Lenovo G40-30 LCD Screen Replacement: paso 2, imagen 2 de 3 Lenovo G40-30 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 2 Lenovo G40-30 LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 2
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: paso 5, imagen 1 de 2 Lenovo G40-30 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: paso 6, imagen 1 de 3 Lenovo G40-30 LCD Screen Replacement: paso 6, imagen 2 de 3 Lenovo G40-30 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: paso 7, imagen 1 de 2 Lenovo G40-30 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Now you have removed the screen and are ready to install a new one.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Contestar
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 2,580
