Saltar al contenido principal
Lenovo Flex 6-11IGM Trackpad Replacement
Qué necesitas
  1. Lenovo Flex 6-11IGM Trackpad Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Trackpad Replacement: paso 2, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: paso 2, imagen 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Trackpad Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Trackpad Replacement: paso 4, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: paso 4, imagen 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Trackpad Replacement, Battery: paso 5, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Trackpad Replacement: paso 6, imagen 1 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: paso 6, imagen 2 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: paso 6, imagen 3 de 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Trackpad Replacement: paso 7, imagen 1 de 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: paso 8, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement, Trackpad: paso 8, imagen 2 de 2
    • Remove the connecting wire labelled "TP" by lifting the tab with the opening tool.
  9. Lenovo Flex 6-11IGM Trackpad Replacement: paso 9, imagen 1 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: paso 9, imagen 2 de 3 Lenovo Flex 6-11IGM Trackpad Replacement: paso 9, imagen 3 de 3
    • Disconnect the keyboard ribbon from the motherboard by lifting the black tab and pulling the ribbon out with the opening tool.
  10. Lenovo Flex 6-11IGM Trackpad Replacement: paso 10, imagen 1 de 1
    • Pull up the black safety tape.
  11. Lenovo Flex 6-11IGM Trackpad Replacement: paso 11, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: paso 11, imagen 2 de 2
    • Remove the three silver 2.3 mm Phillips #00 screws.
    • The third one is under the black tape.
  12. Lenovo Flex 6-11IGM Trackpad Replacement: paso 12, imagen 1 de 2 Lenovo Flex 6-11IGM Trackpad Replacement: paso 12, imagen 2 de 2
    • Slide the trackpad up from its seat using the opening tool and remove it.
Conclusión
Rie Kuraoka
Miembro Desde 01/23/20
913 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S7-G10, Paton Spring 2020 Miembro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 327
