Saltar al contenido principal
Lenovo Flex 6-11IGM Heat Sink Replacement
Qué necesitas
  1. Lenovo Flex 6-11IGM Heat Sink Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 2, imagen 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: paso 2, imagen 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 4, imagen 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: paso 4, imagen 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: paso 5, imagen 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the five 3.9 mm Phillips #00 black screws holding the battery in place.
  6. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 6, imagen 1 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement: paso 6, imagen 2 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement: paso 6, imagen 3 de 3
    • Pull out the multicolored connecting cables using an iFixit opening tool.
  7. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 7, imagen 1 de 1
    • Remove the now disconnected battery from the laptop.
  8. Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: paso 8, imagen 1 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: paso 8, imagen 2 de 3 Lenovo Flex 6-11IGM Heat Sink Replacement, Heat Sink: paso 8, imagen 3 de 3
    • Disconnect the ribbon connector from both ends by disengaging the black latch and pulling it directly from its port.
  9. Lenovo Flex 6-11IGM Heat Sink Replacement: paso 9, imagen 1 de 2 Lenovo Flex 6-11IGM Heat Sink Replacement: paso 9, imagen 2 de 2
    • Remove the 3.5 mm length screws in the numbered order from 1-10 using the Phillips #00 screwdriver (not all are shown in the first image).
    • Remove the heat sink.
Conclusión
Rie Kuraoka
Miembro Desde 01/23/20
913 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S7-G10, Paton Spring 2020 Miembro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 306
