Saltar al contenido principal
Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
Qué necesitas
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: paso 1, imagen 1 de 1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 2, imagen 1 de 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 2, imagen 2 de 2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 4, imagen 1 de 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 4, imagen 2 de 2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: paso 5, imagen 1 de 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: paso 5, imagen 2 de 3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: paso 5, imagen 3 de 3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 6, imagen 1 de 2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: paso 6, imagen 2 de 2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
Conclusión
Una persona más ha completado esta guía.
Rie Kuraoka
Miembro Desde 01/23/20
886 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S7-G10, Paton Spring 2020 Miembro de Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 360
