Saltar al contenido principal
Lenovo Flex 3-1120 Speakers Replacement
Qué necesitas
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Flex 3-1120 Speakers Replacement: paso 2, imagen 2 de 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: paso 3, imagen 1 de 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: paso 4, imagen 1 de 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: paso 5, imagen 1 de 1
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: paso 6, imagen 1 de 2 Lenovo Flex 3-1120 Speakers Replacement: paso 6, imagen 2 de 2
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: paso 7, imagen 1 de 2 Lenovo Flex 3-1120 Speakers Replacement: paso 7, imagen 2 de 2
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: paso 8, imagen 1 de 1
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Conclusión
Geoff Bentz
Miembro Desde 03/09/16
934 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 404
