Saltar al contenido principal
Lenovo Flex 2-14 Hard Drive Replacement
Qué necesitas
  1. Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Make sure your laptop is off before you begin.
    • Flip the laptop over so the bottom is facing upwards.
    • Remove all nine 6mm Phillips #0 screws located along the edges and in the centre of the back panel.
  2. Lenovo Flex 2-14 Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo Flex 2-14 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using a prying tool, carefully lift up the keyboard.
  3. Lenovo Flex 2-14 Hard Drive Replacement: paso 3, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 3, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Take out the keyboard by disconnecting the cable.
  4. Lenovo Flex 2-14 Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo Flex 2-14 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove all four 3.5 mm Phillips screws underneath the keyboard.
  5. Lenovo Flex 2-14 Hard Drive Replacement: paso 5, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 5, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 5, imagen 3 de 3
    • Separate the top and bottom panels of the laptop using a prying tool.
    • Slide the prying tool along the edges of the laptop until the bottom panel is completely separated.
    • Remove the back cover of the laptop once you have finished prying it open.
  6. Lenovo Flex 2-14 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the two 4 mm Phillips screws holding the hard drive adapter in place.
  7. Lenovo Flex 2-14 Hard Drive Replacement: paso 7, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 7, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 7, imagen 3 de 3
    • Take out the adapter containing the hard drive from the laptop.
    • Remove all four 4mm Phillips screws from the adapter.
  8. Lenovo Flex 2-14 Hard Drive Replacement: paso 8, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 8, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Remove the hard drive from the adapter.
    • Insert the new hard drive into the adapter.
  9. Lenovo Flex 2-14 Hard Drive Replacement: paso 9, imagen 1 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 9, imagen 2 de 3 Lenovo Flex 2-14 Hard Drive Replacement: paso 9, imagen 3 de 3
    • Put all four 4mm Phillips screws back into the adapter with the hard drive, in order to hold it in place.
    • Put the adapter back in and reassemble the laptop.
    • Before reassembling, make sure the hard drive is securely in the case.
Conclusión
2 personas más completaron esta guía.
Eva Beilin
Miembro Desde 05/10/20
223 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 47
Todo El Tiempo: 3,822
