Saltar al contenido principal
Lenovo Essential G570 Fan Replacement
Qué necesitas
  1. Lenovo Essential G570 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 Fan Replacement: paso 2, imagen 1 de 2 Lenovo Essential G570 Fan Replacement: paso 2, imagen 2 de 2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 Fan Replacement: paso 3, imagen 1 de 2 Lenovo Essential G570 Fan Replacement: paso 3, imagen 2 de 2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 Fan Replacement, Back Panel: paso 4, imagen 1 de 1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 Fan Replacement: paso 5, imagen 1 de 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 Fan Replacement: paso 6, imagen 1 de 3 Lenovo Essential G570 Fan Replacement: paso 6, imagen 2 de 3 Lenovo Essential G570 Fan Replacement: paso 6, imagen 3 de 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 Fan Replacement, Fan: paso 7, imagen 1 de 2 Lenovo Essential G570 Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Carefully pull the fan's power connector from the laptop.
  8. Lenovo Essential G570 Fan Replacement: paso 8, imagen 1 de 2 Lenovo Essential G570 Fan Replacement: paso 8, imagen 2 de 2
    • Remove the three 5mm Phillips #1 screws holding the fan in place.
  9. Lenovo Essential G570 Fan Replacement: paso 9, imagen 1 de 2 Lenovo Essential G570 Fan Replacement: paso 9, imagen 2 de 2
    • Remove the fan by pulling it up and away from the computer.
Conclusión
2 personas más completaron esta guía.
Lucio
Miembro Desde 03/06/18
217 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 20
Todo El Tiempo: 631
