Saltar al contenido principal
Lenovo Essential G570 Back Panel Replacement
Qué necesitas
  1. Lenovo Essential G570 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn the laptop over so that the bottom side is facing up.
  2. Lenovo Essential G570 Back Panel Replacement: paso 2, imagen 1 de 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  3. Lenovo Essential G570 Back Panel Replacement: paso 3, imagen 1 de 3 Lenovo Essential G570 Back Panel Replacement: paso 3, imagen 2 de 3 Lenovo Essential G570 Back Panel Replacement: paso 3, imagen 3 de 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
Conclusión
3 personas más completaron esta guía.
Justin Bickford
Miembro Desde 03/01/18
446 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 1,538
