Saltar al contenido principal
Lenovo Essential G560 RAM Replacement
Qué necesitas
  1. Lenovo Essential G560 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 RAM Replacement: paso 2, imagen 1 de 2 Lenovo Essential G560 RAM Replacement: paso 2, imagen 2 de 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 RAM Replacement: paso 3, imagen 1 de 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 RAM Replacement, Back Panel: paso 4, imagen 1 de 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 RAM Replacement: paso 5, imagen 1 de 2 Lenovo Essential G560 RAM Replacement: paso 5, imagen 2 de 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 RAM Replacement: paso 6, imagen 1 de 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 RAM Replacement, RAM: paso 7, imagen 1 de 2 Lenovo Essential G560 RAM Replacement, RAM: paso 7, imagen 2 de 2
    • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
  8. Lenovo Essential G560 RAM Replacement: paso 8, imagen 1 de 2 Lenovo Essential G560 RAM Replacement: paso 8, imagen 2 de 2
    • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
    • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
  9. Lenovo Essential G560 RAM Replacement: paso 9, imagen 1 de 1
    • Gently pull out the stick of RAM.
    • If you wish to remove the second stick of RAM, do so by following steps two and three again.
Conclusión
5 personas más completaron esta guía.
Dennis Wong
Miembro Desde 01/11/13
609 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 18-40, Regan Winter 2013 Miembro de Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Miembros
7 Guías creadas
Un comentario
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 11,130
