Saltar al contenido principal
Lenovo Essential G560 Back Panel Replacement
Qué necesitas
  1. Lenovo Essential G560 Back Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Back Panel Replacement: paso 2, imagen 1 de 2 Lenovo Essential G560 Back Panel Replacement: paso 2, imagen 2 de 2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Back Panel Replacement: paso 3, imagen 1 de 1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Back Panel Replacement, Back Panel: paso 4, imagen 1 de 1
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
  5. Lenovo Essential G560 Back Panel Replacement: paso 5, imagen 1 de 2 Lenovo Essential G560 Back Panel Replacement: paso 5, imagen 2 de 2
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Lenovo Essential G560 Back Panel Replacement: paso 6, imagen 1 de 1
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Conclusión
4 personas más completaron esta guía.
Lawrence Downs
Miembro Desde 01/11/13
383 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-40, Regan Winter 2013 Miembro de Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 4,828
