Saltar al contenido principal
Lenovo Essential G555-0873 RAM Replacement
Qué necesitas
  1. Lenovo Essential G555-0873 RAM Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 RAM Replacement: paso 2, imagen 1 de 1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 RAM Replacement, RAM: paso 3, imagen 1 de 3 Lenovo Essential G555-0873 RAM Replacement, RAM: paso 3, imagen 2 de 3 Lenovo Essential G555-0873 RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle.
  4. Lenovo Essential G555-0873 RAM Replacement: paso 4, imagen 1 de 1
    • Pull the RAM stick out of its socket.
  5. Lenovo Essential G555-0873 RAM Replacement: paso 5, imagen 1 de 1
    • Push apart hinges of lower RAM stick until it pops up to a similar angle.
  6. Lenovo Essential G555-0873 RAM Replacement: paso 6, imagen 1 de 1
    • Pull out second RAM stick in the same way as the first.
  7. Lenovo Essential G555-0873 RAM Replacement: paso 7, imagen 1 de 2 Lenovo Essential G555-0873 RAM Replacement: paso 7, imagen 2 de 2
    • Push RAM sticks in diagonally, then push down and snap it in with hinges.
    • Make sure that the RAM stick is aligned with the notch on the port when inserting it.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 247
