Saltar al contenido principal
Lenovo Essential G555-0873 Heat Sink Replacement
Qué necesitas
  1. Lenovo Essential G555-0873 Heat Sink Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 Heat Sink Replacement: paso 2, imagen 1 de 1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 Heat Sink Replacement, Fan: paso 3, imagen 1 de 1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 Heat Sink Replacement: paso 5, imagen 1 de 1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 Heat Sink Replacement, Heat Sink: paso 6, imagen 1 de 1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 Heat Sink Replacement: paso 7, imagen 1 de 2 Lenovo Essential G555-0873 Heat Sink Replacement: paso 7, imagen 2 de 2
    • Pull the heat sink assembly out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 185
