Saltar al contenido principal
Lenovo Essential B570 Back Panel Replacement
Qué necesitas
  1. Lenovo Essential B570 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  2. Lenovo Essential B570 Back Panel Replacement: paso 2, imagen 1 de 3 Lenovo Essential B570 Back Panel Replacement: paso 2, imagen 2 de 3 Lenovo Essential B570 Back Panel Replacement: paso 2, imagen 3 de 3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
Conclusión
4 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 4-5, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-5, Catania Fall 2015
UMASSD-CATANIA-F15S4G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,229
