Saltar al contenido principal
Lenovo Edge 2-1580 Motherboard Replacement
Qué necesitas
  1. Lenovo Edge 2-1580 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Motherboard Replacement: paso 2, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Motherboard Replacement: paso 3, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 3, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Motherboard Replacement: paso 4, imagen 1 de 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: paso 5, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: paso 5, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Motherboard Replacement: paso 6, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 6, imagen 2 de 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Motherboard Replacement: paso 7, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 7, imagen 2 de 2
    • Carefully, using your hand, remove the hard drive from the laptop.
  8. Lenovo Edge 2-1580 Motherboard Replacement, Fan: paso 8, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: paso 8, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: paso 8, imagen 3 de 3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  9. Lenovo Edge 2-1580 Motherboard Replacement: paso 9, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 9, imagen 2 de 2
    • Grab the network card and gently pull it out.
  10. Lenovo Edge 2-1580 Motherboard Replacement: paso 10, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 10, imagen 2 de 2
    • Pull out the RAM metallic cover.
  11. Lenovo Edge 2-1580 Motherboard Replacement: paso 11, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 11, imagen 2 de 2
    • Grab the black insulating tape and pull it out.
  12. Lenovo Edge 2-1580 Motherboard Replacement: paso 12, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 12, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  13. Lenovo Edge 2-1580 Motherboard Replacement: paso 13, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 13, imagen 2 de 2
    • Unplug the Fan connector from its socket on the motherboard.
  14. Lenovo Edge 2-1580 Motherboard Replacement: paso 14, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 14, imagen 2 de 2
    • Carefully remove the fan from the laptop.
  15. Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: paso 15, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: paso 15, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
    • Disconnect these connectors from the motherboard.
    • Disconnect the four ribbon cables from the motherboard.
    • Unscrew and remove the (2) two Phillips #0 screws.
  16. Lenovo Edge 2-1580 Motherboard Replacement: paso 16, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 16, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 16, imagen 3 de 3
    • Lift up the black latch of the ribbon cable with the brown tab on top by holding the cable in to the motherboard.
    • Grab the tab with a pair of pliers and pull out the cable.
  17. Lenovo Edge 2-1580 Motherboard Replacement: paso 17, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 17, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 17, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Lift the beige latch of the ribbon cable with the blue tab by holding the cable in to the motherboard, and with a pair of tweezers, pull out the cable.
  18. Lenovo Edge 2-1580 Motherboard Replacement: paso 18, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 18, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 18, imagen 3 de 3
    • Lift up the black latch of the ribbon cable with the blue tab at the lower right corner of the motherboard and disconnect it with a pair of tweezers.
    • Grab the tab and pull out the cable.
  19. Lenovo Edge 2-1580 Motherboard Replacement: paso 19, imagen 1 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 19, imagen 2 de 3 Lenovo Edge 2-1580 Motherboard Replacement: paso 19, imagen 3 de 3
    • Locate the last ribbon cable with a blue tab and lift the beige latch holding the cable in to the motherboard.
    • With a pair of tweezers grab the tab and remove the cable.
  20. Lenovo Edge 2-1580 Motherboard Replacement: paso 20, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 20, imagen 2 de 2
    • Lift the black latch of the black connector at the top left corner of the motherboard by holding it in to the motherboard.
    • Grab the cable and pull it outwards to remove it.
  21. Lenovo Edge 2-1580 Motherboard Replacement: paso 21, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 21, imagen 2 de 2
    • Pull the wire besides the brown tab ribbon cable out and disconnect it.
  22. Lenovo Edge 2-1580 Motherboard Replacement: paso 22, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 22, imagen 2 de 2
    • Grab the small black connector by the RAM module and disconnect it from the motherboard.
  23. Lenovo Edge 2-1580 Motherboard Replacement: paso 23, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 23, imagen 2 de 2
    • Unplug the remaining connector besides the RAM module and remove it from the motherboard.
  24. Lenovo Edge 2-1580 Motherboard Replacement: paso 24, imagen 1 de 2 Lenovo Edge 2-1580 Motherboard Replacement: paso 24, imagen 2 de 2
    • Gently grab the motherboard and pull it up lightly. Then pull it towards you and remove the motherboard.
Conclusión
4 personas más completaron esta guía.
Julian Escallon
Miembro Desde 09/27/17
714 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S14-G1, Boczar Fall 2017 Miembro de USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 33
Todo El Tiempo: 2,283
