Saltar al contenido principal
Lenovo Edge 2-1580 Fan Replacement
Qué necesitas
  1. Lenovo Edge 2-1580 Fan Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Fan Replacement: paso 2, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Fan Replacement: paso 3, imagen 1 de 3 Lenovo Edge 2-1580 Fan Replacement: paso 3, imagen 2 de 3 Lenovo Edge 2-1580 Fan Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Fan Replacement: paso 4, imagen 1 de 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Fan Replacement, Fan: paso 5, imagen 1 de 3 Lenovo Edge 2-1580 Fan Replacement, Fan: paso 5, imagen 2 de 3 Lenovo Edge 2-1580 Fan Replacement, Fan: paso 5, imagen 3 de 3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  6. Lenovo Edge 2-1580 Fan Replacement: paso 6, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 6, imagen 2 de 2
    • Grab the network card and gently pull it out.
  7. Lenovo Edge 2-1580 Fan Replacement: paso 7, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 7, imagen 2 de 2
    • Pull out the RAM metallic cover.
  8. Lenovo Edge 2-1580 Fan Replacement: paso 8, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 8, imagen 2 de 2
    • Grab the black insulating tape and pull it out.
  9. Lenovo Edge 2-1580 Fan Replacement: paso 9, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 9, imagen 2 de 2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  10. Lenovo Edge 2-1580 Fan Replacement: paso 10, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 10, imagen 2 de 2
    • Unplug the Fan connector from its socket on the motherboard.
  11. Lenovo Edge 2-1580 Fan Replacement: paso 11, imagen 1 de 2 Lenovo Edge 2-1580 Fan Replacement: paso 11, imagen 2 de 2
    • Carefully remove the fan from the laptop.
Conclusión
Julian Escallon
Miembro Desde 09/27/17
714 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S14-G1, Boczar Fall 2017 Miembro de USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
Miembros de 4
5 Guías creadas
2 comentarios
Looks like heat sink and fan are one unit. Advice for regular dust cleaning? How was the condition of the factory thermal paste?
cfryhover - Contestar
Where can one find this fan?
Gabriel Rivera - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 724
