Saltar al contenido principal
Lenovo Edge 15 Wireless LAN Card Replacement
Qué necesitas
  1. Lenovo Edge 15 Wireless LAN Card Replacement, Wireless LAN Card: paso 1, imagen 1 de 1
    • With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
  2. Lenovo Edge 15 Wireless LAN Card Replacement: paso 2, imagen 1 de 1
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Wireless LAN Card Replacement: paso 3, imagen 1 de 1
    • Remove single 3mm screw holding down the end of the card using a Phillips #1 screwdriver.
  4. Lenovo Edge 15 Wireless LAN Card Replacement: paso 4, imagen 1 de 2 Lenovo Edge 15 Wireless LAN Card Replacement: paso 4, imagen 2 de 2
    • Use hands to disconnect card from slot and remove both cables.
    • When replacing connectors be sure to reconnect to proper terminal. Do this by orienting as is in the picture and attaching black cable to left side and white cable to right side.
Conclusión
To reassemble your device, follow these instructions in reverse order. Make sure that connectors are in proper position as shown in step 3.
2 personas más completaron esta guía.
ryan sanders
Miembro Desde 09/27/17
350 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S8-G1, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,565
