Saltar al contenido principal
Lenovo Edge 15 Battery Replacement
Qué necesitas
  1. Lenovo Edge 15 Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Edge 15 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Battery Replacement: paso 2, imagen 1 de 2 Lenovo Edge 15 Battery Replacement: paso 2, imagen 2 de 2
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Battery Replacement: paso 3, imagen 1 de 3 Lenovo Edge 15 Battery Replacement: paso 3, imagen 2 de 3 Lenovo Edge 15 Battery Replacement: paso 3, imagen 3 de 3
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Battery Replacement: paso 4, imagen 1 de 2 Lenovo Edge 15 Battery Replacement: paso 4, imagen 2 de 2
    • Gently lift all four corners of the battery to remove it from the laptop.
Conclusión
5 personas más completaron esta guía.
Cody Griffith
Miembro Desde 09/27/17
321 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S8-G1, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Miembros
7 Guías creadas
2 comentarios
Can I recharge a fully drained battery by reseating it?
Linda - Contestar
My laptop caught on fire don't recommend
Rahem Gang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 59
Todo El Tiempo: 8,573
