Saltar al contenido principal
Lenovo B575-1450 Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo B575-1450 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Lenovo B575-1450 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Wi-Fi Card Replacement: paso 3, imagen 1 de 3 Lenovo B575-1450 Wi-Fi Card Replacement: paso 3, imagen 2 de 3 Lenovo B575-1450 Wi-Fi Card Replacement: paso 3, imagen 3 de 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Wi-Fi Card Replacement, Back Panel: paso 4, imagen 1 de 2 Lenovo B575-1450 Wi-Fi Card Replacement, Back Panel: paso 4, imagen 2 de 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 Wi-Fi Card Replacement, Wi-Fi Card: paso 7, imagen 1 de 1
    • Using the plastic opening tool, detach both black and grey cables from the Wi-Fi card.
  8. Lenovo B575-1450 Wi-Fi Card Replacement: paso 8, imagen 1 de 1
    • Using the Phillips #00 Screwdriver, remove the one 3.4 mm screw from the Wi-Fi card.
  9. Lenovo B575-1450 Wi-Fi Card Replacement: paso 9, imagen 1 de 1
    • Remove Wi-Fi card from the laptop by pulling it out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,073
