Saltar al contenido principal
Lenovo B575-1450 CD-ROM Drive Replacement
Qué necesitas
  1. Lenovo B575-1450 CD-ROM Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 CD-ROM Drive Replacement: paso 2, imagen 1 de 2 Lenovo B575-1450 CD-ROM Drive Replacement: paso 2, imagen 2 de 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 CD-ROM Drive Replacement: paso 3, imagen 1 de 3 Lenovo B575-1450 CD-ROM Drive Replacement: paso 3, imagen 2 de 3 Lenovo B575-1450 CD-ROM Drive Replacement: paso 3, imagen 3 de 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: paso 4, imagen 1 de 2 Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: paso 4, imagen 2 de 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 CD-ROM Drive Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 CD-ROM Drive Replacement: paso 6, imagen 1 de 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: paso 7, imagen 1 de 2 Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: paso 7, imagen 2 de 2
    • Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
    • This unlocks the CD-ROM drive from the computer
  8. Lenovo B575-1450 CD-ROM Drive Replacement: paso 8, imagen 1 de 2 Lenovo B575-1450 CD-ROM Drive Replacement: paso 8, imagen 2 de 2
    • Pry CD-ROM drive from laptop using a plastic opening tool.
    • Pull the CD-ROM drive the rest of the way out.
Conclusión
Un comentario
Can u please show me how to assemble or fix dvd drive lock mechanism for lenovo e49.
nukuvsh4 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 479
