Saltar al contenido principal
Lenovo B575-1450 Back Panel Removal
Qué necesitas
  1. Lenovo B575-1450 Back Panel Removal, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Back Panel Removal: paso 2, imagen 1 de 2 Lenovo B575-1450 Back Panel Removal: paso 2, imagen 2 de 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Back Panel Removal: paso 3, imagen 1 de 3 Lenovo B575-1450 Back Panel Removal: paso 3, imagen 2 de 3 Lenovo B575-1450 Back Panel Removal: paso 3, imagen 3 de 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Back Panel Removal, Back Panel: paso 4, imagen 1 de 2 Lenovo B575-1450 Back Panel Removal, Back Panel: paso 4, imagen 2 de 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 Back Panel Removal: paso 5, imagen 1 de 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 Back Panel Removal: paso 6, imagen 1 de 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 1,259
