Saltar al contenido principal
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
Qué necesitas
Resumen del Video
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: paso 2, imagen 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: paso 2, imagen 2 de 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: paso 3, imagen 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: paso 3, imagen 2 de 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): paso 4, imagen 1 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): paso 4, imagen 2 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): paso 4, imagen 3 de 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: paso 5, imagen 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: paso 5, imagen 2 de 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: paso 6, imagen 1 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: paso 6, imagen 2 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: paso 6, imagen 3 de 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: paso 7, imagen 1 de 1
    • That's all.
Conclusión
3 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,882 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,516 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 38
Todo El Tiempo: 7,379
