Saltar al contenido principal
Lenovo A8-50 Battery Replacement
Qué necesitas
  1. Lenovo A8-50 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover by prying it open with the metal spudger tool.
  2. Lenovo A8-50 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two screws with a PH000 head screwdriver.
    • Keep all your screws in one place.
  3. Lenovo A8-50 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the metal piece.
    • Keep this piece safe, as you will need it to reassemble the device again.
  4. Lenovo A8-50 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery by lifting it up using a plastic spudger.
  5. Lenovo A8-50 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the cable from the connection.
    • Be careful not to tear or bend the cable.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,684
