Saltar al contenido principal
Lenovo A7-40, A7-50 A3500 Factory Reset
Qué necesitas
Resumen del Video
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: paso 1, imagen 1 de 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: paso 1, imagen 2 de 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: paso 1, imagen 3 de 3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: paso 2, imagen 1 de 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: paso 2, imagen 2 de 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: paso 2, imagen 3 de 3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
Conclusión
33 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,278 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,528 Guías creadas
17 comentarios
Is it applicable to my lenovo a516?
valvinzon - Contestar
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 31
Ultimos 30 días: 116
Todo El Tiempo: 106,138
