Introducción
The USB ports and Charging port are soldered together and are ordered as one part, so this guide showcases how to remove and replace both the USB ports and the charging port. If it’s a problem with the battery charging, make sure the battery isn’t the issue before moving on to this guide.
Qué necesitas
Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
Una persona más ha completado esta guía.
Un comentario
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
