Saltar al contenido principal
Lenovo 300e Chromebook USB and Charging Ports Replacement
Qué necesitas
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 2, imagen 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 2, imagen 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 2, imagen 3 de 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: paso 3, imagen 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: paso 3, imagen 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: paso 3, imagen 3 de 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 4, imagen 1 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 4, imagen 2 de 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: paso 4, imagen 3 de 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 47
Todo El Tiempo: 1,535
