Saltar al contenido principal
Lenovo 300e Chromebook Speakers Replacement
Qué necesitas
  1. Lenovo 300e Chromebook Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Speakers Replacement: paso 2, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 2, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 2, imagen 3 de 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Speakers Replacement, Battery: paso 3, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement, Battery: paso 3, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement, Battery: paso 3, imagen 3 de 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Speakers Replacement: paso 4, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 4, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 4, imagen 3 de 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Speakers Replacement, Speakers: paso 5, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement, Speakers: paso 5, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement, Speakers: paso 5, imagen 3 de 3
    • Remove a single 5 mm screw from each speaker using a Phillips #2 screwdriver.
  6. Lenovo 300e Chromebook Speakers Replacement: paso 6, imagen 1 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 6, imagen 2 de 3 Lenovo 300e Chromebook Speakers Replacement: paso 6, imagen 3 de 3
    • Disconnect the speaker cable from the motherboard.
    • Remove the speakers from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 189
