Saltar al contenido principal
Lenovo 300e Chromebook 2nd Gen Battery Replacement
Qué necesitas
  1. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: paso 1, imagen 1 de 3 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: paso 1, imagen 2 de 3 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Phillips #0 Screwdriver
    $5.49
    Comprar
    • Make sure you power off your Chromebook first as you will be disconnecting the battery!
    • Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
    • The screws circled on this Chromebook's back casing are all identical!
    • Use an opening tool such as a spudger and carefully work your way around the laptop to remove the back cover
  2. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: paso 2, imagen 1 de 2 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: paso 2, imagen 2 de 2
    • Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
  3. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: paso 3, imagen 1 de 2 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Remove the 4 screws holding in the battery and set them aside
    • Make sure to separate the screws for the battery from the screws for the backing that were removed in the first step!
Conclusión
2 personas más completaron esta guía.
Zachary Costello
Miembro Desde 07/15/21
153 Reputación
1 Guía escrita
Equipo
Zeeland Public Schools Miembro de Zeeland Public Schools
Business
2 Miembros
1 Guía escrita
Un comentario
It should be mentioned that "newer" models of this particular Chromebook are/have been released. The Chromebooks' battery compartment's design have been slightly modified in that the battery compartment are now reversed.
So, since the battery's connector cable is so short, it's impossible to twist it to fit.
So, make sure you're getting the correct battery for the correct "model".
FYI, the "older" models have the power button close to the back corner of the device, and the "newer" models have the power button near the middle of the device.
Christopher Mali-Martinez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 69
Todo El Tiempo: 2,370
