Saltar al contenido principal
Lenovo 100s Chromebook-11IBY Webcam Replacement
Qué necesitas
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: paso 1, imagen 1 de 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 3, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 3, imagen 2 de 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 4, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 5, imagen 1 de 1
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 6, imagen 1 de 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Conclusión
Milton Perez
Miembro Desde 03/09/17
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S7-G2, Cagle Spring 2017 Miembro de USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Miembro
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 356
